» ASTE E COPPIE CONICHE
Da donatellosca Ieri alle 11:55 pm
» Castor c40
Da MainecooN Ieri alle 8:25 pm
Da pellegrinelli roberto Ieri alle 7:56 pm
Da pellegrinelli roberto Ieri alle 7:55 pm
» Nuova Stihl MS 462
Da luca31 Ieri alle 7:49 pm
» cavalletto da taglio
Da sanremese Ieri alle 6:12 pm
» Husqvarna 365 non si spegne
Da Frank Boscaiolo Ieri alle 1:35 pm
Da Frank Boscaiolo Ieri alle 1:26 pm
Da Celli Enrico Ieri alle 11:13 am
Da Celli Enrico Ieri alle 10:24 am
» Cilindro decespugliatore Husqvarna 152 RJ
Da simosardegna89 Ieri alle 8:24 am
Da Piero1777 Mer Gen 17, 2018 8:44 pm
Da miguel1 Mer Gen 17, 2018 8:09 pm
Da simmy106 Mer Gen 17, 2018 7:56 pm
» motozappa Benassi BL 75
Da falcetto Mer Gen 17, 2018 7:41 pm
» pescante benzina efco 147
Da sanremese Mer Gen 17, 2018 7:25 pm
» OLIVO
Da speedsonic Mer Gen 17, 2018 6:31 pm
» Correttore automatico e testi incomprensibili
Da ferrari-tractor Mer Gen 17, 2018 11:41 am
» CHE TEMPO FA: Domande e commenti sulla meteo
Da stihl Mer Gen 17, 2018 10:06 am
» carro zaccaria 50 40 m
Da ferrari-tractor Mer Gen 17, 2018 7:21 am
Da Shondave Mar Gen 16, 2018 10:10 pm
» Cesti, cestini, gerle...
Da ferrari-tractor Mar Gen 16, 2018 5:48 pm
Da riveraver Mar Gen 16, 2018 4:55 pm
» motosega alpina 380
Da falcetto Mar Gen 16, 2018 3:51 pm
» ceppi di olivo da spaccare
Da amelanchier Mar Gen 16, 2018 7:22 am
» ALBERI MONUMENTALI
Da Ghepardo Lun Gen 15, 2018 10:29 pm
Da Ghepardo Lun Gen 15, 2018 9:47 pm
Da Elciu Lun Gen 15, 2018 8:15 pm
Da ferrari-tractor Lun Gen 15, 2018 7:56 pm
» Stihl 034,ridargli vita
Da stihl Lun Gen 15, 2018 6:46 pm
» Pompa olio husqvarna 365
Da nitro52 Lun Gen 15, 2018 5:08 pm
Da ferrari-tractor Lun Gen 15, 2018 12:39 pm
Da iury1977 Lun Gen 15, 2018 8:22 am
» esplosi husqvarna 135
Da lucky62 Dom Gen 14, 2018 9:00 pm
Da shineon82 Dom Gen 14, 2018 7:36 pm
» INGEGNERIA NATURALISTICA
Da marvinm Dom Gen 14, 2018 6:40 am
» MOTOCARRIOLE
Da marvinm Dom Gen 14, 2018 6:20 am
Da lucamurialdo Sab Gen 13, 2018 8:09 pm
Da luca31 Sab Gen 13, 2018 7:50 pm
Da rappys Sab Gen 13, 2018 5:59 pm
Abbiamo 17296 membri registrati
L'ultimo utente registrato è agnuva88
I nostri membri hanno inviato un totale di 226775 messaggi in 10921 argomenti
In totale ci sono 25 utenti in linea: 3 Registrati, 0 Nascosti e 22 Ospiti :: 1 Motore di ricerca
Alessio510, davide depaoli, Ghepardo
Serbatoio olio sverniciato
Messaggio  DotCom il Ven Ago 23, 2013 7:28 pm
Ciao ,
oggi ho notato sull'angolo anteriore del carter in magnesio della mia 452s una lieve sverniciatura, ho prontamente collegato questa cosa all'olio visto che me ne è caduto un pò in quella zona essendo sotto il tappo dell'olio catena. Ho quindi svuotato la mts dell'olio e ho guardato nel serbatoio. Con mio rammarico era alquanto sverniciato , ovvero si vedevano i puntini di vernice rossa su fondo color metallo tipo quando si spruzza la vernice. Ho subito cambiato olio.
Ho verificato che l'olio fuoriuscisse regolarmente e ho impostato la pompa alla portata massima. L'olio esce normalmente, o almeno così sembra.
La domanda è, devo preoccuparmi? Non vorrei sostituire la pompa dell'olio dopo pochi mesi di utilizzo, ho usato sempre e solo olio ecologico , l'ultima volta mischiato ad un 10mm di nafta+10W40. Forse è stato proprio questo miscuglio ad innalzare l'acidità dell'olio che ha sverniciato carter e serbatoio? E' possibile che le particelle di vernice siano state bloccate dal filtro olio?
Tuttavia non sono sicuro che il carter è stato sverniciato dall'olio , potrebbe anche essere stato un tronchetto .... non so come comportarmi sinceramente.
Data d'iscrizione : 01.11.12
Re: Serbatoio olio sverniciato
Messaggio  Don Camillo il Dom Ago 25, 2013 12:52 pm
A mio parere,ritengo improbabile che l`olio catena anche se addizionato alla nafta possa portare a sverniciature di sorta.
Detto per inciso,per altri motivi comunque io eviterei di miscelare l`olio catena con altre sostanze.Ma questo è un altro discorso.
Riguardo ai puntini di vernice rossa,sempre a mio parere,potrebbe trattarsi di un problema verificatosi già in catena di montaggio.
Non penso possano pregiudicare il corretto funzionamento del sistema di lubrifica.
Se fossi al tuo posto continuerei ad utilizzare la motosega senza preoccupazioni. ok capo
Buon pomeriggio da D.C.Very Happy
Età : 53
Messaggio  tottoli livio il Dom Ago 25, 2013 4:49 pm
fai una cosa abbastanza semplice: controlla il filtro nel serbatoio olio...se e' pulito...continua a utilizzare la motosega senza preoccupazioni..ok capo
Messaggio  DotCom il Dom Ago 25, 2013 8:01 pm
Grazie ad entrambi, rincuora un parere positivo dato da chi è più esperto di me. Detto questo ho controllato il filtro olio ed è lindo e pinto, ho utilizzato la mts tutta la giornata di ieri nel bosco , abbattendo anche piante di 45cm di diametro senza problemi.
Tornando al discorso vernice spruzzata , se fosse un problema di verniciatura della catena di montaggio sarebbe comunque un problema relativo , alla fine non pregiudica il corretto funzionamento della mts ne l'estetica della stessa. La sverniciata lieve , visibile nella parte anteriore del carter è stata quasi sicuramente causata da un taglio troppo vicino ai tronchi messi su cavalletto , oppure è stato un tronco saltato... Spero che non si allarghino ulteriormente, (ovviamente presterò una maggior attenzione nel taglio) , in caso contrario alla fine di questa stagione chiederò consigli su come verniciare il carter motore bonk!bonk!
Grazie di nuovo e buona serata.
