» ASTE E COPPIE CONICHE
Da donatellosca Ieri alle 11:55 pm
» Castor c40
Da MainecooN Ieri alle 8:25 pm
Da pellegrinelli roberto Ieri alle 7:56 pm
Da pellegrinelli roberto Ieri alle 7:55 pm
» Nuova Stihl MS 462
Da luca31 Ieri alle 7:49 pm
» cavalletto da taglio
Da sanremese Ieri alle 6:12 pm
» Husqvarna 365 non si spegne
Da Frank Boscaiolo Ieri alle 1:35 pm
Da Frank Boscaiolo Ieri alle 1:26 pm
Da Celli Enrico Ieri alle 11:13 am
Da Celli Enrico Ieri alle 10:24 am
» Cilindro decespugliatore Husqvarna 152 RJ
Da simosardegna89 Ieri alle 8:24 am
Da Piero1777 Mer Gen 17, 2018 8:44 pm
Da miguel1 Mer Gen 17, 2018 8:09 pm
Da simmy106 Mer Gen 17, 2018 7:56 pm
» motozappa Benassi BL 75
Da falcetto Mer Gen 17, 2018 7:41 pm
» pescante benzina efco 147
Da sanremese Mer Gen 17, 2018 7:25 pm
» OLIVO
Da speedsonic Mer Gen 17, 2018 6:31 pm
» Correttore automatico e testi incomprensibili
Da ferrari-tractor Mer Gen 17, 2018 11:41 am
» CHE TEMPO FA: Domande e commenti sulla meteo
Da stihl Mer Gen 17, 2018 10:06 am
» carro zaccaria 50 40 m
Da ferrari-tractor Mer Gen 17, 2018 7:21 am
Da Shondave Mar Gen 16, 2018 10:10 pm
» Cesti, cestini, gerle...
Da ferrari-tractor Mar Gen 16, 2018 5:48 pm
Da riveraver Mar Gen 16, 2018 4:55 pm
» motosega alpina 380
Da falcetto Mar Gen 16, 2018 3:51 pm
» ceppi di olivo da spaccare
Da amelanchier Mar Gen 16, 2018 7:22 am
» ALBERI MONUMENTALI
Da Ghepardo Lun Gen 15, 2018 10:29 pm
Da Ghepardo Lun Gen 15, 2018 9:47 pm
Da Elciu Lun Gen 15, 2018 8:15 pm
Da ferrari-tractor Lun Gen 15, 2018 7:56 pm
» Stihl 034,ridargli vita
Da stihl Lun Gen 15, 2018 6:46 pm
» Pompa olio husqvarna 365
Da nitro52 Lun Gen 15, 2018 5:08 pm
Da ferrari-tractor Lun Gen 15, 2018 12:39 pm
Da iury1977 Lun Gen 15, 2018 8:22 am
» esplosi husqvarna 135
Da lucky62 Dom Gen 14, 2018 9:00 pm
Da shineon82 Dom Gen 14, 2018 7:36 pm
» INGEGNERIA NATURALISTICA
Da marvinm Dom Gen 14, 2018 6:40 am
» MOTOCARRIOLE
Da marvinm Dom Gen 14, 2018 6:20 am
Da lucamurialdo Sab Gen 13, 2018 8:09 pm
Da luca31 Sab Gen 13, 2018 7:50 pm
Da rappys Sab Gen 13, 2018 5:59 pm
Abbiamo 17296 membri registrati
L'ultimo utente registrato è agnuva88
I nostri membri hanno inviato un totale di 226775 messaggi in 10921 argomenti
In totale ci sono 48 utenti in linea: 7 Registrati, 0 Nascosti e 41 Ospiti :: 1 Motore di ricerca
alep1960, Alessio510, davide78, luca31, MainecooN, mikhele, pellegrinelli roberto
Cambio olio B&S
Cambio olio B&S
Messaggio  Perugino76 il Mar Feb 25, 2014 6:06 pm
Salve a tutti, vi volevo chiedere....vorrei cambiare l'olio del motore al tosaerba con motore B&S. Ebbene dopo diversi mesi al freddo del box, l'ho messo in moto e fatto girare per un minuti circa, spento messo su dei cavalletti , tolto il tappo dell'olio e l'ho inclinato da quella parte per farlo defluire...devo far così poichè il tappo inferiore è coperto dalla lamiera.
Fatto scolare per bene mi sono accorto che era poco meno di 0,3 litri!
Vado a vedere sul manuale e mi dice che il motore ne deve contenere: 0,54-0,59 l
Ora la mia domanda è: ho sbagliato qualcosa oppure?
Quando l'ho utilizzato l'ultima volta il livello dell'olio era normale, anzi forse anche un pelo abbondante...
Non l'ho fatto scaldare troppo ed è rimasto all'interno?
Non so che pensare? Voi che dite?
Grazie!!
Perugino76
Data d'iscrizione : 26.05.13
Re: Cambio olio B&S
Messaggio  tottoli livio il Mar Feb 25, 2014 6:34 pm
Perugino76 ha scritto:Salve a tutti, vi volevo chiedere....vorrei cambiare l'olio del motore al tosaerba con motore B&S. Ebbene dopo diversi mesi al freddo del box, l'ho messo in moto e fatto girare per un minuti circa, spento messo su dei cavalletti , tolto il tappo dell'olio e l'ho inclinato da quella parte per farlo defluire...devo far così poichè il tappo inferiore è coperto dalla lamiera.
Grazie!!
esattamente diciamo per arrotondare 0.5 l....mettici l'olio e verifica con l'astina se e' come dici dovrebbe segnarti il livello molto piu' alto del massimo..quindi o sbagli a misurare o l'astina non e' giusta.  Very Happy
Re: Cambio olio B&S
Messaggio  Perugino76 il Mar Feb 25, 2014 6:53 pm
Allora questa è la prima volta che me lo cambio io a casa, precedentemente (era in garanzia) l'hanno fatto in officina. Quindi ho fatto come sopra e l'olio che ne è uscito è meno di 0,3l, mentre sul manuale riporta 0,54-0,59L....ecco perchè non so che pensare....
Se faccio come dici tu e ci metto l'olio nuovo, se fosse che ne è rimasto ancora si mischierebbe con quello vecchio e poi che faccio? Lo tolgo e ne compro un'altro litro??
Non mi pare molto logico...
Il Tosaerba è questo:
http://www.agritek.passweb.it/negozio/prodotti/giardinaggio--forestale/rasaerba-a-scoppio-trazionati/tosaerba-snapper-19-traz-dov-700-3-in-1-erdsp19700
Perugino76
Re: Cambio olio B&S
Messaggio  tottoli livio il Mar Feb 25, 2014 7:03 pm
se lo hai fatto scolare tutto ne rimane qualche goccia....
Re: Cambio olio B&S
Messaggio  Perugino76 il Mar Feb 25, 2014 7:11 pm
tottoli livio ha scritto:se lo hai fatto scolare  tutto  ne rimane qualche goccia....
Io l'ho piegato sul lato del tubo di scolo, e poi (come dice il manuale), con la candela rivolta verso l'alto....ma di olio non ne esce più.....
Quindi, o quest'estate "girava" con meno olio del dovuto, oppure me lo sono "perso" quest'inverno, ma di pozze nel garage non ce ne sono....
Possibile che il manuale riporti un dato sbagliato?
Oppure il mio dubbio è che non l'abbia scaldato molto e quindi non riesce a defluire del tutto?
Ma cavolo l'olio era di 2 anni, non nuovissimo ma manco nero come la pece,in quanto alla vischiosità se lo sbatto si muove abbastanza fluido.....
Perugino76
Re: Cambio olio B&S
Messaggio  tottoli livio il Mar Feb 25, 2014 7:20 pm
alt..fammi capire...per togliere l'olio hai svitato il tappo con la chiave quadra??(che si trova nella parte inferiore del motore) o hai tolto il tappo dove c'e' l'astina e hai ribaltato la macchina??
Re: Cambio olio B&S
Messaggio  Perugino76 il Mar Feb 25, 2014 8:53 pm
Non ci arrivo al tappo quadro INFERIORE, perchè dovrei smontare il motore dal telaio del tosaerba.
Quindi l'ho fatto scaldare per un minutino, e poi una volta tolto il tappo dell'olio SUPERIORE (quello con l'astina), ho ribaltato il tosaerba, e fatto scolare tutto l'olio.
Tra l'altro ora che ci ripenso, tempo fa pulii il tosaerba dal lato sbagliato, in pratica lo inclinai dal lato del carburatore....una volta riacceso non vi dico che fumata che si è fatto!!
Ha durato per un bun 5 minuti prima di diventare accettabile.....possibile che l'olio che mi manchi me lo sia "fumato" (nel vero senso della parola ahahha), in quell'occasione?
Perugino76
Re: Cambio olio B&S
Messaggio  Ghepardo il Mar Feb 25, 2014 10:40 pm
Se davvero l'olio mancante è "andato in fumo" come dici, vuol dire che da allora il motore ha lavorato con metà olio Shocked  rispetto al previsto... ma dopo la fumata non avevi più controllato il livello?
Re: Cambio olio B&S
Messaggio  Perugino76 il Mer Feb 26, 2014 8:00 am
Non mi ricordo se è stato l'ultimo taglio dell'erba, e poi l'ho riposto.....
Stamattina provo o rimetterlo dentro e vedere a che livello arriva sull'astina....
Perugino76
Re: Cambio olio B&S
Messaggio  Alessio510 il Mer Feb 26, 2014 8:16 am
se lo inclini parecchio, è normale che poi fuma, perchè travasa l'olio in camera di scoppio. Il mio B&S 35 ormai (dopo 13 anni di carriera) un po ne mangia, infatti lo tengo controllato... ma il fatto che abbia lavorato con metà olio... non è così grave.
Banalmente potrebber aver sbagliato la quantità all'ultimo cambio in officina... fai il cambio, usalo qualche volta e controlla il livello....  ok capo
Re: Cambio olio B&S
Messaggio  Perugino76 il Mer Feb 26, 2014 1:00 pm
Stamattina ho riprovato a scolarlo diverse volte, e alla fine ne ho tolto un pochetitno meno di mezzo kilo, quindi considerato il tempo che l'ho usato, quello che si è "fumato" con il mio errore, e che un pochettino ne sarà rimasto cmq dentro, direi che ormai ci siamo.
Appena il tempo volge al meglio, lo riempo di Castrol Garden 4T e ricominciamo a falciare...
Grazie mille a tutti!
Ne approfitto per chiedervi un'altro consiglio, ma la lama come si smonta? bisogna girare in senso orario o antiorario? Io non ci sono riuscito....ho notato che un pochettino con i residui di erba si è un pò ossidata, e in officina l'hanno sempre smontata con la pistola ad aria compressa. Ho messo un pò di WD40 ma non mi si svita......
Perugino76
Re: Cambio olio B&S
Messaggio  riccardo il Mer Feb 26, 2014 4:07 pm
Perugino76 ha scritto: ma la lama come si smonta? bisogna girare in senso orario o antiorario.......
Si smonta in senso antiorario.
Data d'iscrizione : 01.10.10
Re: Cambio olio B&S
Messaggio  tottoli livio il Mer Feb 26, 2014 6:18 pm
quando rimonti la lama mettici un pochino di grasso sul filetto del bullone...
ancora una domanda sul cambio olio..ma scusami come fai a non accedere al tappo con la sede quadra??..solitamente e' lasciato appunto libero per lo scarico dell'olio.. Very Happy
Re: Cambio olio B&S
Messaggio  Perugino76 il Mer Feb 26, 2014 8:31 pm
Il tappo con la sede quadra in bassa è mezzo coperto dal telaio, lo vedo ma non ci si riesce ad infilare la chiave per svitarlo e se per qualche strano motivo ce la farei, poi l'olio colerebbe sul telaio spargendosi ovunque.....
Bisognerebbe dirlo ai progettisti della Snapper....probabilmente non hanno preso bene le misure quando l'hanno progettato........e si che sarebbe bastato fargli un asola nel telaio e tutti questi problemi non c'erano.....e' proprio vero: prima di comprare una cosa bisognerebbe provarla!
Inoltre in tre anni il cestello si è molto deteriorato, la vernice è saltato in molte zone e ha preso un pò di ruggine. E si che ogni volta che ho finito di tagliare il prato lo pulisco per bene e soffio con il compressore. In più ogni 2/3 volte che lo uso lo pulisco anche con il raggio d'acqua.....mah...
Stamattina oltre all'olio ho dato una bella passata con il trapano e la spazzola in acciaio, ripassato con quella manuale, dato una bella passata di antiruggine e un pò di convertitore dove proprio non ci arrivavo....ora appena torna il sole due belle mani di vernice e siamo a posto.....
Certo per fare un bel lavoro bisognava liberare il cestello da tutti gli altri accessori, motore compreso, farlo sabbiare e poi riverniciarlo.....magari un'altra volta.
Perugino76
Re: Cambio olio B&S
Messaggio  Perugino76 il Lun Mar 03, 2014 5:45 pm
Allora, oggi approfittando del bel tempo ho riverniciato il sottoscocca, e ho messo il nuovo olio nel motore. Mi son detto: ora ne metto meno di 0,54l, che ci dovrebbe andare, così lo lascio riposare un pò e poi rimisuro...bene ne metto 0,25/0,3l.  Metto il tosaerba in piano e lo lascio li un 5/10 minuti, in modo che l'olio si depositi per bene. Dopodichè vado a misurare e sull'astina (pulita) misura già il MAX!!! Ma come cavolo è possibile? Ora anche ammettendo che ne sia rimasto dentro un pò di quello vecchio , ne ho tolto quasi 0,45l, ora con il nuovo con appena 0,3l sono già al max??? Qualcosa non mi torna.....
Ora lo lascio riposare tutta la notte e domattina rimisuro.....
Voi come fate?
Grazie mille!
P.S = Cavolo è stato più facile cambiare olio e filtro sull'auto che sul tosaerba.... Crying or Very sad grrr
Perugino76
Re: Cambio olio B&S
Messaggio  tottoli livio il Lun Mar 03, 2014 5:55 pm
Perugino76 ha scritto:Allora, oggi approfittando del bel tempo ho riverniciato il sottoscocca, e ho messo il nuovo olio nel motore. Mi son detto: ora ne metto meno di 0,54l, che ci dovrebbe andare, così lo lascio riposare un pò e poi rimisuro...bene ne metto 0,25/0,3l.  Metto il tosaerba in piano e lo lascio li un 5/10 minuti, in modo che l'olio si depositi per bene. Dopodichè vado a misurare e sull'astina (pulita) misura già il MAX!!! Ma come cavolo è possibile? Ora anche ammettendo che ne sia rimasto dentro un pò di quello vecchio , ne ho tolto quasi 0,45l, ora con il nuovo con appena 0,3l sono già al max??? Qualcosa non mi torna.....
Voi come fate?
Grazie mille!
questo mistero mi sta' incuriosendo...per cortesia ci posti qualche foto della macchina e da' sotto dove c'e' la lama?? grazie.. ?????
Re: Cambio olio B&S
Messaggio  falcetto il Mar Mar 04, 2014 8:37 pm
Per favore sarebbe utile una foto del tappo olio con asta perchè ce ne sono di varie misure e forme. Non vorrei che per qualche motivo la tua non è quella esattamente prevista per il tuo motore. Saluti
Re: Cambio olio B&S
Messaggio  Perugino76 il Mer Mar 05, 2014 9:16 am
Allora, ieri mattina dopo che è stato fermo tutta la notte, sono andato a rimisurare l'olio presente ed il livello era sotto il minimo! Allora ho aggiunto altro olio per un totale di mezzo litro o poco più e rimisurandolo nel pomeriggio inoltrato, misurava appena sotto il MAX.
Dato che sul manuale riporta come capacità d'olio 0,54L-0,59L, direi che ci siamo.....stamattina per sicurezza ri-misuro con prima una bella "grattata", non si sa mai....
Ora mi domano come mai ci metta cosi' tanto per "posarsi".....sul manuale dice dopo qualche minuto, mah......
Cmq ecco le foto del tosaerba:
Per quanto riguarda l'astina, è come la prima a sinistra della foto sopra, cambia la forma del tappo ma per il resto mi pare uguale.
Perugino76
Re: Cambio olio B&S
