» ASTE E COPPIE CONICHE
Da donatellosca Ieri alle 11:55 pm
» Castor c40
Da MainecooN Ieri alle 8:25 pm
Da pellegrinelli roberto Ieri alle 7:56 pm
Da pellegrinelli roberto Ieri alle 7:55 pm
» Nuova Stihl MS 462
Da luca31 Ieri alle 7:49 pm
» cavalletto da taglio
Da sanremese Ieri alle 6:12 pm
» Husqvarna 365 non si spegne
Da Frank Boscaiolo Ieri alle 1:35 pm
Da Frank Boscaiolo Ieri alle 1:26 pm
Da Celli Enrico Ieri alle 11:13 am
Da Celli Enrico Ieri alle 10:24 am
» Cilindro decespugliatore Husqvarna 152 RJ
Da simosardegna89 Ieri alle 8:24 am
Da Piero1777 Mer Gen 17, 2018 8:44 pm
Da miguel1 Mer Gen 17, 2018 8:09 pm
Da simmy106 Mer Gen 17, 2018 7:56 pm
» motozappa Benassi BL 75
Da falcetto Mer Gen 17, 2018 7:41 pm
» pescante benzina efco 147
Da sanremese Mer Gen 17, 2018 7:25 pm
» OLIVO
Da speedsonic Mer Gen 17, 2018 6:31 pm
» Correttore automatico e testi incomprensibili
Da ferrari-tractor Mer Gen 17, 2018 11:41 am
» CHE TEMPO FA: Domande e commenti sulla meteo
Da stihl Mer Gen 17, 2018 10:06 am
» carro zaccaria 50 40 m
Da ferrari-tractor Mer Gen 17, 2018 7:21 am
Da Shondave Mar Gen 16, 2018 10:10 pm
» Cesti, cestini, gerle...
Da ferrari-tractor Mar Gen 16, 2018 5:48 pm
Da riveraver Mar Gen 16, 2018 4:55 pm
» motosega alpina 380
Da falcetto Mar Gen 16, 2018 3:51 pm
» ceppi di olivo da spaccare
Da amelanchier Mar Gen 16, 2018 7:22 am
» ALBERI MONUMENTALI
Da Ghepardo Lun Gen 15, 2018 10:29 pm
Da Ghepardo Lun Gen 15, 2018 9:47 pm
Da Elciu Lun Gen 15, 2018 8:15 pm
Da ferrari-tractor Lun Gen 15, 2018 7:56 pm
» Stihl 034,ridargli vita
Da stihl Lun Gen 15, 2018 6:46 pm
» Pompa olio husqvarna 365
Da nitro52 Lun Gen 15, 2018 5:08 pm
Da ferrari-tractor Lun Gen 15, 2018 12:39 pm
Da iury1977 Lun Gen 15, 2018 8:22 am
» esplosi husqvarna 135
Da lucky62 Dom Gen 14, 2018 9:00 pm
Da shineon82 Dom Gen 14, 2018 7:36 pm
» INGEGNERIA NATURALISTICA
Da marvinm Dom Gen 14, 2018 6:40 am
» MOTOCARRIOLE
Da marvinm Dom Gen 14, 2018 6:20 am
Da lucamurialdo Sab Gen 13, 2018 8:09 pm
Da luca31 Sab Gen 13, 2018 7:50 pm
Da rappys Sab Gen 13, 2018 5:59 pm
Abbiamo 17296 membri registrati
L'ultimo utente registrato è agnuva88
I nostri membri hanno inviato un totale di 226775 messaggi in 10921 argomenti
In totale ci sono 34 utenti in linea: 3 Registrati, 0 Nascosti e 31 Ospiti :: 1 Motore di ricerca
Alessio510, davide depaoli, Ghepardo
Motosega Alpina P 400 -Serbatoio miscela
Messaggio  ferdinando58 il Lun Dic 29, 2014 8:37 am
Salve,
ho da circa 3 anni una motosega Alpina P 400 della quale sono abbastanza contento. Purtroppo una volta lo scorso anno e anche questo. si è verificato il seguente inconveniente: dopo il rifornimento di carburante si nota  una discreta perdita ( gocciolamento) che continua per un po' non capisco cos apuò essere e come porvi rimedio.
Avete qualche suggerimento da darmi?
PS: complimenti per il forum è molto utile
Ultima modifica di Ghepardo il Lun Dic 29, 2014 8:44 am, modificato 1 volta (Motivazione : spostato in sezione adeguata)
ferdinando58
Data d'iscrizione : 13.03.12
Re: Motosega Alpina P 400 -Serbatoio miscela
Messaggio  nespolo 65 il Lun Dic 29, 2014 10:27 am
ciao ferdinando benvenuto sul forum,ma sei riuscito a capire da dove proviene la perdita? dal tappo di rifornimento? in questo caso sostituisci la guarnizione.......
Messaggio  worior il Lun Dic 29, 2014 10:41 am
Se non proviene dal tappo rifornimento ,cosa molto probabile,magari ti perde il gommino passatubo in pratica è un gommino tondo montato sul serbatoio con al centro i fori per far passare i tubicini che portano miscela al carburatore Prova queste due ipotesi e facci sapere
Data d'iscrizione : 02.12.13
Messaggio  tottoli livio il Lun Dic 29, 2014 10:59 am
se posti qualche foto del punto dove gocciola sara' piu' facile darti qualche consiglio ok capo
Messaggio  ferdinando58 il Lun Dic 29, 2014 12:05 pm
Grazie dei suggerimenti, escludo il tappo per il rifornimento mentre potrebbe essere il gommino dove passano i due tubicini. In questo caso per la sua sostituzione/riparazione devo smontare il serbatoio della miscela?
Questo pomeriggio faccio delle altre prove, poi vi faccio sapere.
Nel disegno che ho scaricato dal forum purtroppo non compaiono la parte del serbatoio con il gommino di cui sopra.
Avete qualche altro disegno?
ferdinando58
Messaggio  nitro52 il Lun Dic 29, 2014 3:20 pm
sei sicuro che non perde dallo sfiato del serbatoio ?????
comunque segui il consiglio di Tottoli posta una foto
alpina 45 prof golden
Messaggio  aldebaran/48 il Gio Gen 22, 2015 7:29 pm
nitro52 ha scritto:sei sicuro che non perde dallo sfiato del serbatoio ?????
Pongo un quesito che non trova risposta neanche negli esplosi.
Ho una mts Alpina Prof 45 Golden(con freno lama) alla quale voglio sostituire il filtro della benzina e il tubo pescante.
Il filtro non esce dal tappo e il tubo è in alto del serbatoio e inarrivabile per sfilarlo dal raccordo in plastica, visto che ha anche una fascetta elastica che lo tiene fermo.
Il tubo si è vetrificato e si frantuma a guardarlo; sospetto che tubo e filtro siano stati montati prima di chiudere il serbatoio. può essere o non ho capito come fare?
Forse il serbatoio era un ricambio senza manutenzione?
-per evitare questi problemi svuotare sempre i serbatoi delle mts a riposo-
grazie.
aldebaran/48
aldebaran/48
Data d'iscrizione : 20.01.13
Età : 69
http://augusto.giacomelli@virgilio.it
Messaggio  nitro52 il Ven Gen 23, 2015 2:49 pm
non ho mai visto nella mia poca esperienza mts le quali sia impossibile sostituire il tubo benzina e relativo filtro.
se il filtro e' attaccato al tubo prendi un fil di ferro con un uncino sulla punta e dopo averlo infilato dal tappo mix agganci il tubo e lo sfili dal tappo mix stesso cosi' esce anche il filtro, per sostituire il tubo parti da dove entra nel carburatore e vai a ritroso cosi' arrivi nel serbatoio spero di essermi spiegato
magari posta una foto
ciao nitro ok capo Very Happy
alpina 45 prof
Messaggio  aldebaran/48 il Ven Gen 23, 2015 10:25 pm
tutte le mts che ho incontrato non ho mai avuto problemi di manutenzione del serbatoio.
sost. tubi o filtri erano accessibili, nella 45 il filtro è in parte in feltro molto grande
attaccato ad un porta-filtro che non passa dal tappo;il tubo benz.ha un raccordo
sotto il tappo inaccessibile primo perché non ci si vede,secondo perché non ci si arriva.......guardare per credere
un salutone aldebaran/48
Ultima modifica di Nonno_sprint il Ven Gen 23, 2015 10:26 pm, modificato 1 volta (Motivazione : Eliminato " Quote " del messaggio precedente: superfluo.)
aldebaran/48
Età : 69
Messaggio  massimo 64 il Ven Gen 23, 2015 10:52 pm
Guarda la figura n.21 a pagina 16 nel manuale di officina di Alpina/Castor 45 e ti indica che con una pinzetta a becchi lunghi lo puoi estrarre il filtro, probabilmente dovrai prima staccare la spugnetta del filtro visto che dici che non passa dal tappo serbatoio ,dai una controllata al manuale se già non lo hai fatto .saluti
Data d'iscrizione : 11.05.14
