» TESTINE A FILO e fili di vario genere - PARTE 2Da ferrari-tractor Oggi alle 11:53 am
Da Stef62 Oggi alle 9:13 am
Da Ghepardo Oggi alle 9:09 am
Da luca31 Oggi alle 6:31 am
Da hiller Ieri alle 10:48 pm
Da luca31 Ieri alle 9:57 pm
Da undelfino Ieri alle 7:26 pm
Da SuperUCCU Ieri alle 6:28 pm
Da pw31 Ieri alle 3:02 pm
Da galero96 Ieri alle 2:37 pm
Da superciuck72 Ieri alle 12:27 pm
Da gabri93 Ieri alle 11:49 am
Da filigrana Ieri alle 2:42 am
Da falcetto Dom Mar 17, 2024 7:23 pm
Da SuperUCCU Dom Mar 17, 2024 7:22 pm
Da falcetto Dom Mar 17, 2024 6:22 pm
Da RasKebir Dom Mar 17, 2024 5:46 pm
Da Nejc Dom Mar 17, 2024 4:52 pm
Da nitro52 Dom Mar 17, 2024 1:43 pm
Da sgaragnone Sab Mar 16, 2024 6:06 pm
Da alfredo_cavallo1 Sab Mar 16, 2024 5:12 pm
Da Ghepardo Sab Mar 16, 2024 1:34 pm
Da fabio 57 Sab Mar 16, 2024 10:14 am
Da luca31 Sab Mar 16, 2024 8:00 am
Da Otello52 Ven Mar 15, 2024 8:18 pm
Da Gian60 Ven Mar 15, 2024 7:44 pm
Da andariel85 Ven Mar 15, 2024 6:23 pm
Da Gian Ossola Ven Mar 15, 2024 4:49 pm
Da nitro52 Ven Mar 15, 2024 4:45 pm
Da falcetto Ven Mar 15, 2024 11:03 am
Da RasKebir Ven Mar 15, 2024 8:30 am
Da Otello52 Gio Mar 14, 2024 10:48 pm
Da Erne Gio Mar 14, 2024 8:44 pm
Da gabri93 Gio Mar 14, 2024 3:27 pm
Da Gian60 Gio Mar 14, 2024 1:59 pm
Da luca31 Gio Mar 14, 2024 8:50 am
Da Fast 34 Gio Mar 14, 2024 7:09 am
Da Mannaia Gio Mar 14, 2024 6:23 am
Da luca31 Mer Mar 13, 2024 10:36 pm
Da Manuele97 Mer Mar 13, 2024 9:33 pm
In totale ci sono 372 utenti online: 6 Registrati, 0 Nascosti e 366 Ospiti :: 2 Motori di ricercaboscocastagno, ferrari-tractor, galero96, JackTheNightFly, paolo69, thor1
ASCE - ACCETTE parte 4
+106
Fast 34
nicolo83
Paolone
lucaxx
superfunk
Birka56
Eugenio Rigo
Franco2021
Fede_22
fabio 57
IlFaco
pipporan
ulmus
nikibrik
Etto
Roberto Volpi
etorty
Luigi il calabrese
Camaro71
DavideVonC.
larice giallo
SCIROKKO87
giancarbon
podet73
boscocastagno
wolfnyght
m150
phantom
entoni
huginn
Na paca de legne
angeloz
luca.
piccolododo
Carlozzo
tribo
Dudum
alson
alex95
Celli Enrico
gianfederico
femalix
Mighelle
menenic
Charles2014
alexjz4
paolo73
marco46
davide78
Angelo85
vanloon
baffus
Tonino95
lagarduna
Cecco97
superciuk
controller
nerocagliostro
Beppe 1978
110 partecipanti
Pagina 24 di 41
Pagina 24 di 41 • 1 ... 13 ... 23, 24, 25 ... 32 ... 41
Re: ASCE - ACCETTE parte 4
Anche con Orsoarcubo (l'ottimo Luca Simoni) si era parlato di "mancini" qualche tempo fa...
https://lamotosega.forumattivo.com/t118p100-asce-accette-parte-1#27546
beppe65- ex moderatori
Data d'iscrizione : 03.10.10
un discorso è dare semplici consigli ... un altro conto è avere la competenza per poter insegnare delle tecniche. Le tecniche sono importanti in ogni pratica. Poi ognuno è libero di applicarle oppure nomikhele ha scritto:... si possono dare tutti i consigli possibili ma che in ogni caso sono soggettivi, e proprio per questo non andrebbero dati.
(in ogni caso questa è solamente la mia opinione.)
Sono pienamente d'accordo con Luca che le tecniche sono molto importanti per aumentare e migliorare l'efficienza della maggior parte dei lavori.
Io però mi riferivo al fatto che non si dovrebbe cambiare, invertire l'uso degli arti dominanti. Anche se con il tempo si potranno ottenere dei buoni risultati, mi sembra un po' contro natura.
mikhele- utente registrato
Data d'iscrizione : 31.10.12
Vi propongo un'altra chiave di lettura ...
La mano dominante dietro, e quindi fissa sull'attrezzo, può derivare forse dall'abitudine ad impugnare attrezzi monomano, tipo martello, mazzuola,piccole accette, roncola.
Con questi attrezzi chiunque usa la mano dominante e l'attrezzo viene impugnato verso l'estremità del manico, senza alcuno spostamento della mano durante l'azione.
Ecco che allora mi spiego il fatto di usare gli attrezzi più grossi nella medesima maniera, ovvero lasciando alla mano destra le stesse funzioni, mentre la mano sinistra si trova a fare il lavoro aggiuntivo.
Inoltre ... secondo me il concetto di mano dominante è importantissimo per quel che riguarda la precisione, mentre lo è molto di meno per la forza.
Semplicemente, ci sono azioni che generalmente non si possono eseguire (bene) con la mano "sbagliata", scrivere è la più comune; mentre il differenziale di forza tra le due braccia è molto esiguo, se sollevate una cesta con il braccio dominante, sarà molto difficile non riuscirci anche con l'altro.
E comunque per usare certi attrezzi, prima viene la tecnica e poi la forza.
phantom- utente registrato
Data d'iscrizione : 02.05.17
Questo è un esempio di tecnica. Se si fa caso; la didascalia non fa cenno all'arto destro o sinistro, bensì all'arto più forte meglio definito come dominante.
ecco, mikhele, questa tecnica è completamente contraria a quella descritta nel libro 'the ax book' di cui si parla sopra .
E contrario di come faccio ad esempio io. Questa è un' altra tecnica
@Luca31: da paura già solo a vedere la quantità di manico che avanza dopo l'ascia...
Se spacchi legna secca che si rompe un po' come vuole, quando quella parte di manico arriva a toccare il legno ti prendi dei contraccolpi mica da niente.
@mikhele: se alzi tutto un giorno la mazza da 5kg per picchiare sui cunei come fa questo non arrivi a fine giornata...
m150- utente registrato
Data d'iscrizione : 29.10.18
certo che mi fa un po' strano vedere questi tutorial ...
già prima dei 10 anni spaccavo la mia parte di legna in casa ... e nessuno si è mai premunito di farmi vedere come tenere l'accetta
io usavo quella piccola e mio padre quella grande ...
lui il "zocco" grande, quello bello da tenere da parte ... io uno di quelli da spaccare ... e via così a passare le giornate di inverno
bei tempi
bei tempi
stiamo parlando di tecniche, la critica sulla lunghezza del manico sopra la testa, in questo caso non è rilevante.m150 ha scritto:@Luca31: da paura già solo a vedere la quantità di manico che avanza dopo l'ascia...
@mikhele: se alzi tutto un giorno la mazza da 5 kg per picchiare sui cunei come fa questo non arrivi a fine giornata...
Idem per la critica sull'altro video, la tecnica spiegata serve per quel tipo di ascia e per quel tipo di lavoro.
L'argomento è interessante, cerchiamo di fare critiche costruttive e senza uscire dal tema .
Aggiungi la tua tecnica o le tue tecniche abbinate agli attrezzi che usi tu
Io credo che conoscere la tecnica corretta possa essere d'aiuto.
È vero la spontaneità del gesto... ma a volte è giusto anche correggere per rendere più sicuro ed efficace.
A chi interessasse ecco un link ad un manualetto che ha altre interessanti indicazioni sul genere (purtroppo solo in inglese):
https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.bchmt.org/documents/education/AnAxetoGrind.pdf&ved=2ahUKEwiEoK6M0-vfAhXB66QKHfYOBkkQFjAAegQIBBAB&usg=AOvVaw06QPw8uq0pxqD7-W-hMffB&cshid=1547413192965
Luca.
Luca.
luca.- utente registrato
Data d'iscrizione : 14.02.18
Domani vado a comprare quella che dovrebbe essere una mazza-scure per spaccare roba da 20-30 cm
LUX martello da spacco 3.000 g Classic con queste caratteristiche:
Peso:3,84 kg
manico in frassino da 90 cm
testa in acciaio C 45
Contando che sono alto 185 cm dovrebbe andare bene la lunghezza del manico? Altra domanda come marchio e "accettabile"?
Costo 21 euro compreso il manico (mi sembra un'ottimo prezzo, difatti diffido e chiedo a voi)
Peso:3,84 kg
wolfnyght- utente registrato
Data d'iscrizione : 19.01.19
premesso che per iniziare è inutile spendere troppo, il marchio non l'ho mai sentito, sarà il classico prodotto da brico dato il prezzo.
per spaccare probabilmente spacca, da verificare l'ergonomia e la qualità di acciaio (e tempra) e manico. Non cadi dall'alto comunque.
tieni conto che 3kg sono già un bel peso, se hai legno piccola e che si spacca facile ti consiglio di prendere una scure da spacco sui 1.5-2kg.
se hai pezzi grossi e nodosi, comprati anche almeno 3 cunei di cui due belli lunghi ed uno di tipo elicoidale
Le scuri della Lux si trovano anche in vendita nei negozi Obi, ho notato che sono identiche a quelle vendute dalla tedesca Bison, ho chiesto al capo reparto se le Lux fosse rimarchiate da Bison ma non ha saputo rispondere, allora ho inviato una mail a Bison per delucidazioni ma ad oggi sto ancora aspettando la risposta.
Se fosse come penso la qualità delle scuri Lux è senz'altro di prim'ordine.
Roberto
Roberto
Data d'iscrizione : 05.03.11
wolfnyght ha scritto:... per spaccare roba da 20-30 cm
20-30cm di diametro? lunghezza? essenza? già secca?
Io ho sempre avuto tendenza ad usarne di pesanti ma poi ho preso in mano una vecchia scure da spacco di mio padre ed ho notato che non devo rincorrere ogni volta i pezzi che volavano letteralmente via. Cerco di dare un bel colpo che spacchi ma non separi completamente il ciocco in modo da girarlo a 9o° e dividerne una metà in due quarti, 18o° e divido l'altra.
Comunque 21 euri sembrano un investimento tutto sommato molto modesto, e da qualche cosa dovrai pur cominciare!
Lunghezza del manico adeguata e gestibile per la tua altezza nonchè ottima ed abbondante (pure troppo) per diametri 20 -30cm. Penso che la testa pesi meno di 3000 gr. ma poco importa, 21 euri (pochi in effetti) ci stanno per vedere come e se funziona. Facci sapere e buona legna.wolfnyght ha scritto:Domani vado a comprare quella che dovrebbe essere una mazza-scure per spaccare roba da 20-30 cm
Peso:3,84 kg
Io ho la stessa mazzascure (marca, peso, lunghezza) ma la versione con la protezione metallica sulla parte del manico sotto la testa dell'attrezzo (è un po' più cara) -cosa che in qualche circostanza è stata molto utile, perché se ti capita di sbagliare un colpo (e quando sei stanco prima o poi capita), sul manico arrivano certe tranvate che non ti immagini-.
Devo dire che la uso abbastanza e non potrei farne a meno perché è proprio una bestia, un carrarmato. Tra l'altro la uso anche in abbinamento con una mazza pura da 5kg con la quale la batto quando non apre a primo colpo (così uso molto di meno i cunei).
Devo però anche dire che non potrei mai usarla come unica ascia da spacco. Troppo pesante e imprecisa; alla lunga ti sdrena le braccia e non potrei reggere lunghe sessioni.
La uso solo con i ciocchi più testardi e in quei casi è una mano dal cielo.
Se dovessi scegliere un'unica ascia per spaccare andrei certamente su qualcosa di più leggero.
Non so se però è questo il tuo caso,
Luca.
Luca.
Le scuri della Lux si trovano solo nei briko OBI, le ho viste, ma mai prese in considerazione.
A mio parere sono ben rifinite e superiori a molti marchi cinesi, la Q/P è sicuramente ottima. Per iniziare vanno più che bene.
OBI è un briko tedesco, molti loro prodotti vengono prodotti in Germania, quindi sulla provenienza credo che Roberto1962 abbia ragione.
Non ci resta che sentire il parere di wolfnyght.
Buona legna.
Buona legna.
gian66- Moderatori
Visto che si parlava di OBI (Slovenia però), ho visto che hanno una promozione non da poco sui prodotti Fiskars. Ascia x27 per esempio al 50%, che non è poco per un prodotto così buono! Se non fossi già ben attrezzato, l’avrei presa
fim- utente registrato
Data d'iscrizione : 25.01.17
Edizione 1926 Ax 7T
Come avevo precedentemente detto ecco il nuovo arrivoRoberto1962 ha scritto:Neppure io, l'ho acquistata solo perché è una edizione speciale, pensavo di accoppiarla alla scure da spacco della stessa edizione acquistata precedentemente, mentre non penso che acquisterò la piccola accetta così piccole non mi interessano, ma non si sa mai. Comunque questa scure da taglio forgiata dalla Muller è bella e bel rifinita.
Roberto
Accetta Stihl Ax 7T peso gr 700 e manico in frassino da cm 40
quella al centro ha tutta l'aria di essere una bella scure.
si! son belle, lo stile vintage è sempre azzeccato.
complimenti a Roberto, collezione ora completata, io mi sono accontentato di quella più piccola
gian66- Moderatori
Grazie gian66 per i complimenti, mi sono convinto all'acquisto proprio e unicamente per completare la collaborazione.
Roberto
Roberto
Eccomi
Preso la mazzascure Lux
(devo riprendermi... mi sono messo sotto ed ho smesso per sfinimento)
La prima cosa che devo fare : ceppo più alto (non e come la scure, a cui cambio il manico domani)
Parlando del "ferro"
Qualità molto buona :
la testa non ha bave e o intrusioni di scorie, risulta affilata discretamente
Il manico e risultato solo leggermente ruvido all'inizio, con l'utilizzo e migliorato (e ben carteggiato ma rimane una certa porosità)però almeno non ha segni di rotture e o altre amenità.
Utilizzo:
Ovviamente e squilibrata in avanti ma devo dire che ho preso la mano subito, utilizzata per dividere a metà ciocchi di legno da 20-25 cm (gaggia,quercia,castagno,ecc ecc) non ho nemmeno bisogno di spingere, lascio andare guidando la testa, e si divide tutto a metà.
Provata in alcuni pezzi nodosi, per la verità molto nodosi, li ha fatti esplodere in 4 pezzi ==
L'unico difetto, volava legna da tutte le parti ahahah sono andato all'inizio in modalità spacca tutto...ho spaccato sia il legno che il ceppo
Questione fatica: sarò strano io ma con questa, rispetto alla scure, tanto più lavoro e meno fatica
Utilizzo:
Pagina 24 di 41
