» ASTE E COPPIE CONICHE
Da donatellosca Ieri alle 11:55 pm
» Castor c40
Da MainecooN Ieri alle 8:25 pm
Da pellegrinelli roberto Ieri alle 7:56 pm
Da pellegrinelli roberto Ieri alle 7:55 pm
» Nuova Stihl MS 462
Da luca31 Ieri alle 7:49 pm
» cavalletto da taglio
Da sanremese Ieri alle 6:12 pm
» Husqvarna 365 non si spegne
Da Frank Boscaiolo Ieri alle 1:35 pm
Da Frank Boscaiolo Ieri alle 1:26 pm
Da Celli Enrico Ieri alle 11:13 am
Da Celli Enrico Ieri alle 10:24 am
» Cilindro decespugliatore Husqvarna 152 RJ
Da simosardegna89 Ieri alle 8:24 am
Da Piero1777 Mer Gen 17, 2018 8:44 pm
Da miguel1 Mer Gen 17, 2018 8:09 pm
Da simmy106 Mer Gen 17, 2018 7:56 pm
» motozappa Benassi BL 75
Da falcetto Mer Gen 17, 2018 7:41 pm
» pescante benzina efco 147
Da sanremese Mer Gen 17, 2018 7:25 pm
» OLIVO
Da speedsonic Mer Gen 17, 2018 6:31 pm
» Correttore automatico e testi incomprensibili
Da ferrari-tractor Mer Gen 17, 2018 11:41 am
» CHE TEMPO FA: Domande e commenti sulla meteo
Da stihl Mer Gen 17, 2018 10:06 am
» carro zaccaria 50 40 m
Da ferrari-tractor Mer Gen 17, 2018 7:21 am
Da Shondave Mar Gen 16, 2018 10:10 pm
» Cesti, cestini, gerle...
Da ferrari-tractor Mar Gen 16, 2018 5:48 pm
Da riveraver Mar Gen 16, 2018 4:55 pm
» motosega alpina 380
Da falcetto Mar Gen 16, 2018 3:51 pm
» ceppi di olivo da spaccare
Da amelanchier Mar Gen 16, 2018 7:22 am
» ALBERI MONUMENTALI
Da Ghepardo Lun Gen 15, 2018 10:29 pm
Da Ghepardo Lun Gen 15, 2018 9:47 pm
Da Elciu Lun Gen 15, 2018 8:15 pm
Da ferrari-tractor Lun Gen 15, 2018 7:56 pm
» Stihl 034,ridargli vita
Da stihl Lun Gen 15, 2018 6:46 pm
» Pompa olio husqvarna 365
Da nitro52 Lun Gen 15, 2018 5:08 pm
Da ferrari-tractor Lun Gen 15, 2018 12:39 pm
Da iury1977 Lun Gen 15, 2018 8:22 am
» esplosi husqvarna 135
Da lucky62 Dom Gen 14, 2018 9:00 pm
Da shineon82 Dom Gen 14, 2018 7:36 pm
» INGEGNERIA NATURALISTICA
Da marvinm Dom Gen 14, 2018 6:40 am
» MOTOCARRIOLE
Da marvinm Dom Gen 14, 2018 6:20 am
Da lucamurialdo Sab Gen 13, 2018 8:09 pm
Da luca31 Sab Gen 13, 2018 7:50 pm
Da rappys Sab Gen 13, 2018 5:59 pm
Abbiamo 17296 membri registrati
L'ultimo utente registrato è agnuva88
I nostri membri hanno inviato un totale di 226775 messaggi in 10921 argomenti
In totale ci sono 50 utenti in linea: 8 Registrati, 0 Nascosti e 42 Ospiti :: 1 Motore di ricerca
alep1960, Alessio510, davide depaoli, davide78, Ghepardo, luca31, MainecooN, mikhele
Come si smonta lo sfiato del serbatoio benzina?
Messaggio  paullu il Dom Apr 02, 2017 9:05 pm
Ciao a tutti. Sono nuovo su questo forum, spero di fare tutto giusto. Un amico mi ha portato una motosega husqvarna 240 da tempo ferma che non partiva. Sostituito le membrane accendeva ma a fatica e insistendo tanto.
Cosi ho scoperto che la colpa è del serbatoio della benzina che va in pressione. Volevo quindi controllare lo sfiato ma non capisco come va smontato. Ho provato a forzare un po la parte di ottone che si vede in foto senza ottenere risultati bonk!bonk! . Qualcuno più esperto di me sa darmi una mano?
Vi ringrazio
Allego una foto ok capo
paullu
Data d'iscrizione : 02.04.17
Re: Come si smonta lo sfiato del serbatoio benzina?
Messaggio  falcetto il Lun Apr 03, 2017 3:21 pm
Bisogna prima capire se la difficoltà di accensione è causata da poca o troppa miscela nel carburatore. Mi fido che hai diagnosticato sovrapressione nel serbatoio.
A mia conoscenza lo sfiato in foto è piantato a pressione se non addirittura annegato nella fusione plastica. Informati se disponibile come ricambio.
Soffia per bene dall'esterno. Saluti
...e quello della 254?
Messaggio  igorka il Mar Apr 11, 2017 3:10 pm
Aiuto, mi sembra di avere sovrapressione nella mia 254 ma non riesco a capire come si smonta lo sfiato del serbatoio!
Probabilmente sono io il ritardato...
igorka
Data d'iscrizione : 16.11.16
Messaggio  nitro52 il Mar Apr 11, 2017 3:41 pm
Cosa succede si spegne e se apri il tappo della mix vedi bollire ?????
Individua dove è non è detto che si possa smontare
Posta qualche foto
Messaggio  igorka il Mar Apr 11, 2017 4:08 pm
Lunga storia... ma ora non si accende o fa due colpi e se sfilo il tubo dal carburatore esce miscela. Mi sembra che si ingolfi...
igorka
Messaggio  nitro52 il Mar Apr 11, 2017 4:51 pm
C'e' la scintilla, ????? prova a lasciare aperto il tappo mix
Spiega bene quello che succede
Messaggio  Ceppo77 il Mar Apr 11, 2017 5:01 pm
Controlla se associato a questo codice
501 87 31-01
Ha una sfera all'interno?
Messaggio  igorka il Mar Apr 11, 2017 5:46 pm
Ok, Husqvarna 254XP. Nell'esploso della 254 non c'è lo sfiato...
Comunque la storia è questa: a un certo punto la sega comincia a partire male e si spegne dopo pochi colpi.
Mi sembra un problema elettrico e, dopo alcuni tentativi gli cambio la bobina, senza effetti particolari.
La porto dal meccanico che mi dice: non c'è compressione, bisogna cambiare cilindro + pistone, non vale la pena.
Riprendo la sega, sostituisco pistone + cilindro, di concorrenza, ho dovuto rivedere i buchi delle viti ma sembra che sia andata bene. Forse c'è un po' di gioco tra biella e albero ma mi sembra accettabile.
La compressione c'è. La scintilla c'è, Dal decompressore esce, quando provo a lungo, miscela nerastra. Più volte è appena partita...
Una volta è partita per bene, sono riuscito a fargli la carburazione, a provarla (e andava proprio bene quindi direi che il cilindro funziona) anche se a caldo dovevo tenerla su di giri. Una volta spenta non riparte se non per pochi colpi. Ho soffiato tutto il carburatore, ho provato a sostituirlo con quello di un'altra 254XP che va: niente. snort
igorka
