In totale ci sono 576 utenti online: 1 Registrato, 0 Nascosti e 575 Ospiti :: 3 Motori di ricercaferruccio
OLIO MISCELA: TIPI - QUALITA' - DOSI parte 3
+151
Andrea01
GV75
Bartolo82
Celli Enrico
filippo75pg
maremmano
Jefry
RodiZegna
Haski
SuperUCCU
Lucap
alex95
manuel55
Accrocchista
ferrarifxx
Forestmix
Stoazz
zak
Joy
Gianca74
Steox84
marcof12
sfn83
Bryan04
motosegare
Taglialegna96
fireboss
centopercento
Shondave
pierangelo 68
Bakko
ciprovo
frankf
Federico 88
Skywalker
baboone
BAD LANCIA
gianlucapitt
GS
balda
wildwildcat
luigino84
Ducelier
adminale
previxjps
carminecs260
Luparello
Bombo
tatino1971
specialissimo
Febb71
davide78
Giovi
ms192
ciamu
cariol
matrix888
pavona61
Celtico1967
frankrob
boja77
P4ol0
entoni
daniele86
loryktm
boscocastagno
-Campagnolo-
Mario Cagnola
LucaOrse7
SCIROKKO87
Laris61
desmo88
Alfredo Paggi
grimgor
pierio
LorenzoSanguigni
The Red Baron
Fulvio_70
Turin76
JohnnyMac
s.n.
robywood
Beppe 1978
miaobauu
Peso
walterino63
SANTIPPOLITO
AGRICOL-TURI
155 partecipanti
Pagina 14 di 40
Pagina 14 di 40 • 1 ... 8 ... 13, 14, 15 ... 27 ... 40
Re: OLIO MISCELA: TIPI - QUALITA' - DOSI parte 3
2T specifications
Japeneese motorcycle manufacturers found the limits demanded by the API TC specifications too loose. Oils meeting the API TC standard still produced excessive smoke and could not prevent exhaust blocking. Therefore the Japanese Engine Oil Standards Implementation Panel (JASO) introduced the following specifications:
JASO FA
Original spec established regulating lubricity, detergency, initial torque, exhaust smoke and exhaust system blocking.
JASO FB
Increased lubricity, detergency, exhaust smoke and exhaust system blocking requirements over FA.
JASO FC
Lubricity and initial torque requirements same as FB, however far higher detergency, exhaust smoke and exhaust system blocking requirements over FB.
JASO FD
Same as FC with far higher detergency requirement.
API TC – only API spec established for two cycle engines. It regulates lubricity, detergency, ash content and pre-ignition. Oils with this spec are typically using metal-based, ash-producing additives.
è in inglese ma si capisce, se non lo capisci lo traduciamo...
JASO FA
JASO FB
JASO FC
JASO FD
Data d'iscrizione : 10.09.14
Tradotto con google Grazie per l'aiuto e una ottima specifica. Il problema e che dalle mie parti sono chidi su Sthil e olio Stihl "rosso" anche se ES: (dico una cavolata) Olio Stihl rosso e semi sintetico jaso FA e Quello stihl "verde" e jaso fd Sintetico sono chiodi su quello rosso PUNTO e Basta. Per quello io prendevo Strong K Mix Syt, o Motul 710 come tempo fa vedevo su qualche post sul forum.
OK! Grazie per la spiegazione , avevo capivo FC e FD erano buoni ma non tutto il significato completo ora e OK,Ceppo77 ha scritto:Jaso é l' ente certificatore giapponese
Uno dei più severi e forse importante
Il massimo é jaso fd ovvero più la seconda lettera é alta migliore é
Jaso fc + é leggermente e quasi impercettibilmente inferiore
Considera comunque che un jaso f c è considerato già un buon olio
Ultima modifica di falcetto il Mar Gen 05, 2016 7:57 pm - modificato 1 volta. (Motivazione : Rimosso quote messaggio immediatamente precedente)
matrix888- utente registrato
Data d'iscrizione : 20.08.11
Sulla confezione di quest'olio Echo c'è scritto che si tratta di un lubrificante già additivato, protetto contro l'invecchiamento.
È comunque necessario aggiungere l'additivo dopo aver preparato la miscela?
valerio91- utente registrato
Quanto tempo durerà la miscela utilizzando quest'olio? 12 mesi?
leggi sulla confezione, se non c'è lì non so che dirti
Per stare sul sicuro starei max 8 mesi non di più
Lo uso anche io ma sulla confezione non ce scritto
Anticipare la scadenza é meglio
Poi vero che ci sono additivi che durano anche più di un anno ma che dubito ma non sapendolo ...
Ok, vi ringrazio.
Ragazzi ma avete già provato uno Stabilizzatore per carburanti? me l'hanno consigliato per conservare benzina e miscela fino a 2 anni
simmy106- utente registrato
Data d'iscrizione : 26.01.12
Non vorrei dire una fesseria ma mi sembra che duri così tanto quello della emak
Io lo avevo usato tempo fa ma poi basta perché oltre a puzzare mi sembrava molto appiccicoso con la paura di imbrattare il tutto
A mio parere da evitare
Ma era rosso tipo un pò oleoso da aggiungere al carburante?
Proprio quello
Rosso scuro
Confe bianca tappo verde
Rosso scuro
State parlando dell'ADDITIX 2000?
Si quello
Però ho appena guardato il catalogo e lo mettono a 12 mesi
Ricordavo male
Scusami per l'imprecisione
Ricordavo male
Quello che avete utilizzato voi era di colore rosso?
Io lo utilizzo, è trasparente e non è per niente oleoso.
È molto simile al carburante per stufe a petrolio.
Si rosso pesto
Può darsi che l'abbiamo modificato
Prima era a mio parere improponibile
Se lo trovo lo provo!!
Se vi può interessare, in questa discussione si parla della conservazione dei carburanti: https://lamotosega.forumattivo.com/t1864-benzina-e-miscela-conservazione-e-durata?highlight=additivi
buonasera è qualche anno che uso l'olio x miscela dolmar ieri sono andato a comprarlo ma non lo tratta +.Mi a dato un altro olio a un prezzo intaressante 7,5 euro al kg confrontando il dolmar è quello nuovo nelle specifiche sono identici
jaso fd ---global gd----iso-l-egd tranne il dolmar è api tc
mentre quello nuovo è api tc+
cosa vuol dire quel + è migiore quel vecchio o quel nuovo.
Comunque oggi lo provato a livello di fumo è migiore del dolmar
cariol- utente registrato
Data d'iscrizione : 06.09.13
Ciao, sicuramente sono tutti e due ottimi olii, penso che quello che hai comprato ora è Echo Power mix 100% sintetico, è uno dei pochi Api tc+ a quel prezzo.
La classificazione Api ( Ta Tb Tc Tc+ Tc++ ) classifica la pulizia olio, la detergenza, antiossidamento e anticorrosione. In teoria Tc+ è superiore a Tc
Laris61- utente registrato
L' olio nuovo di che marca é?
olio nuovo
l'olio nuovo è il addi-mix della shindaiwa sono bottiglie da 1 kg con dosatore oggi lo usato e mi sembra che il motore sia + brillante ma forse srà una mia impressione comunque rispetto al dolmar fa meno fumo-------------- scusate se mi sono scordato di mettere il nome del olio
É un ottimo olio a bassa fumosità e con un ottimo rapporto qualità prezzo
Se hai sempre rispettato la percentuale anche nell' olio precedente senza eccedere la brillantezza maggiore potrebbe essere però un'impressione? ?!!
lo sto utilizzando in versione Echo e mi trovo piuttosto bene, fumosità molto bassa.
olio miscela by bardhal
Salve a tutti , ho comprato un olio prodotto dalla bardhal per la HL (marchio sconosciuto) perchè mi ha incuriosito e volevo provarlo, in etichetta riporta
- Alto potere lubrificante e detergente
- Maggiore pulizia del motore
- Massima flessibilità di utilizzo
L'indice API è TC
L'indice API è TC
Ultima modifica di Don Camillo il Ven Gen 15, 2016 4:04 am - modificato 2 volte. (Motivazione : Unito a Topic con argomento similare)
dobermann- utente registrato
Data d'iscrizione : 07.11.11
Le caratteristiche riportate che ne esaltano le proprietà sono abbastanza comuni e riportate sulla maggior parte dei flaconi
La sigla t c caratterizza un olio di buona qualità
Leggi per caso altre sigle come jaso, global, ISO? ?
Sarebbero utili per attribuire più o meno qualità
» OLIO MISCELA: TIPI - QUALITA' - DOSI parte 2
» BENZINE: TIPI - QUALITA'
Pagina 14 di 40
